Opacity not correct
Hi, I am facing issues in opacity maps. I have attached image of 3ds max screenshot where I have used gradient opacity map on floor carpet which blends properly in 3ds max, but when I am using the same map in D5 the blending is not visible at all.
Need help in this!! how can I make blending materials properly?
Hi, try clicking the invisible box at the top, but I’m not sure if it activates
nope. didn’t activated.
Hi, have you tried converting the material into a cloth material (Material Template) since this material template has a much more seamless opacity slider when it comes to edges?.
@Clov Thank a lot.
Hi, does the opacity slider only appears on cloth material? because it would be great if other material type also has opacity slider, or you can add opacity slider on custom material :pray:t2:
Hi @3dteam,
The opacity map is not limited to the cloth material alone. It is available for other material templates such as the Transparent template, Displacement template, and Custom Alpha template. For more details on opacity maps and supported templates, please refer to What materials are the Displacement templates suitable for? What are the special parameters? | User Manual
