What is this “lock”-function for? because even when an object is locked, i can reload and move it or change materials on it
Hi mate, The main function of the “lock” is to be not selected(except materials) and moved, Do you think it should lock more according to your real work?
but moving is possible when using the XYZ in Location, also rotate and scale. that should also be locked. so if an object is locked NO changes should be possible (even no material changes)
i have moved “locked” things multiple times accidentally this way
