Hi D5-Team,
I am using the fbx-file between my 3D Software and D5-Render. It works fine but…
After the import, the axes are set in a different position. It’s a big problem for me because I use the correct position as a pivot point.
See example. I have to be able to turn the lower part of the chair exactly around the middle. But the axis is placed in a different location in the D5.
Could you please fix it (by leaving the axis as it is in fbx) or allow to move the axis of an object (or group). It would help a lot.
thank yo in advance
