So after you updated the driver, do all the images you download after using AI Enhancer can open properly now?
yes I can open it
I verified the possibility of updating the driver with the Team and we think itâs still a coincidence. We will optimize it in subsequent versions. ![]()
I feel something connected with internet speed or server speed. For the last few days, it has been working fine now the same issue downloaded but not able to open. I donât think itâs related to the Graphics card, if so lasts 2-3 days it should not work.
Yes, AI Enhancer is cloud-based and may affect access if network conditions are poor. If the download is slow, try switching networks. Sorry for any inconvenience caused. ![]()
finally, I found the solution. I changed the Network configuration in the Router settings from PPPOE to Dynamic.
Now itâs working
I do have the same problem here the enhancement is done like 1 hour ago and it is still
a downloadâŠ
Hi there, sorry for that. You might want to try checking your deviceâs local time and server time if they are in sync. Otherwise, please try syncing them and see if it solves the problem. Let me know if this helps, thank you~
My problem solved with some server settings, âNetwork conf to Dynamicâ I donât know the technical sides of that. For me itâs worked
Thanks for your tip. I guess it has alot to do with the download time after a while it was there⊠![]()
