Currently working on a new office interiors in London. Can someone please help me to fix this? Please see attached. Settings and a snapshot of the interior.
Hi Waldo,
please try to reduce the parameter of Normal, roughness and Metal, the noise issue should be fixed.
Thank you
Jessie - will try this. It seems to work here with the current WC lobby on the cubicle panel doors. I reduced the normal allot. Increased the roughness and reduced the metalness in this image. It worked here.
Struggle sometimes when there is low level of light then noise pops up on surfaces.
Maybe there will be a denoiser effect filter in future builds?
Waldo
Hi there,
Thank you for the suggestion. It’ll be optimized in the following updates.
Look forward to it! Thank you.
Keep up the good work.
