Hello,I want to know why I select marble material in my model, but there are no texture sow on wall or floor. Can anyone Know why is that happened?
Hi there,
I apologize for the inconvenience. Can you share with me which material you used in the asset library? Does this occur in other files as well?
I used a marble material, but the texture doesn’t show up. Only the smooth stone material is visible, while the marble veins are not showing. The same issue occurs with walnut wood as well.(here’s the image)
I use " Brown sand" and " Misty rain stone tile"
“Grey Vision Marble”
Hi there,
I’ve tried applying the materials you mentioned, and I can’t seem to experience the same issue. Can you modify and adjust the UV parameters and see if the marble veins/grains show? Let me know if there are any differences.
Hi There,Thanks. I just adjusted UV parameters,and "Brown sand"still doesn’t work,but others does. Thanks a lot!
Hi there,
I just checked the material asset “Brown Sand” on my end to test if it is malfunctioning but it is working fine.
Were you able to try to adjust the UV Parameters “Stretch” Slider? If yes, and it still did not work, you can send your D5 File to us so we can assess it. You may send it to support@d5techs.com and have it titled “Clov-Forum Brown Sands Material.” Thank you.
OK,I’ll check later Thanks!
