Hi D5-Team,
Reloading my own inserted fbx objects is not possible if the path has changed. If you change the path name or file name “reload” is no more possible.
The ability to show where the file is located would be very helpful. Can you please add this option?
Thank you in advance.
best regards
Hello @Albareus
Thanks for your advice. In this case, you can click ‘‘Replace from Local’’ instead of ‘‘Reload’’. It will prompt ‘‘replace failed’’. However, if you click confirm at this time, it will pop up the file searching window of ‘‘Replace File’’. You can redefine the path to your modified(name/path) file.
