I need some advise on how to achieve the upper style to my rendering (bottom image)
Is my sun setting or what, mine looks darker? Do you have any suggestion I can make use of the AI or in-programme filter function?
I believe this can be adjusted with Sun Intensity or Exposure, modifying the different Environment and Effect settings should let you achieve what you are trying to do.
- You can also try to use AI Atmosphere Match by making the first image as your reference.
