MSI rtx 4060ti gaming x 16gb ddr6
HELLO I NEED HELP IS GOOD THIS FOR D5 MSI rtx 4060ti gaming x 16gb ddr6 ? PLEASE SOMEONE TELL ME THANKS
Hella, i think is a good card and it will run d5 with no problem, you can check in d5 render page what kind of specification you need.
thank you so much for reply . I asked beacause MSI RTX 4060 TI 16GB I DIDN’T SEE IN THE LIST SO i’m buying a new computer with this card and im worried
this are the components of my new comptuer they are good? someone can help? thanks
I5 di 11 gen 11400 con grafica integrata intel Uhd 730
Dissipatore a liquido cooler master da 240mm
Scheda madre MSI MAG b560 Gaming wifi
16gb di ram corsair rgb a 3600mhz
Nvme pcie 4.0 gen da 1 TB
(Scheda video RX 6650 XT della MSI Gaming X or msi rtx 4060ti gaming x 16gb ddr6 ? Which one is better?)
Alimentatore 600 watt 80bronze della Sharkoon
Hi susystable you have to give more specifications of the PC you are buying, what type of operating system it is, what speed the RAM goes at, this is because, if you are new to the forum you have read some users with more powerful graphics cards than what you said have had problems.
You must inform yourself better with one of the D5 Teams, to be sure of the purchase.
Hello I’m buying this one : I5 di 11 gen 11400 con grafica integrata intel Uhd 730
@Ryann-Z
You have to ask D5 teams this before posting it, if it’s ok to run the program. I for my part was lucky from the beginning, but I have a rtx 1070 laptop with 16g and equally another 16g to the system. It gives me great satisfaction, but it’s not an MSI, but an Intel ì7.
And I prefer it over the MSI
It is intel5 11th gen , thanks for reply but where I can find D5 Team?
go to the left where there is the drop-down menu, where all the topics are listed, just click on the help topic, all the topics of the day and other days will appear, next to it there are both users who have asked for help and also one of the teams, I can help you say that one has an icon of a dog, another of a lady from the 18th century, just enter and click on one of these, a larger icon will open with which you can send a letter.
I understand that it is an important purchase depending on the program. You have to be sure before doing this. Strength is Courage
i run d5 with a 3070ti and it run smoothly and good, so a think you wont have any problem
Ok thank you so much to @riccardofortelli and @dtovarmarquez
Hi! I think the card is good enough to support D5. Typically, you’ll need to make sure you have a 1060+ solo graphics card and at least 16g of RAM. For other details, you can refer to this post. System Requirements for D5 Render
Being a dual-slot card, the NVIDIA GeForce RTX 4060 Ti 16 GB draws power from 1x 16-pin power connector, 2048 cupcakes with power draw rated at 165 W maximum You will have to buy any PSU upgrade from HP. HP has a 500W PSU (L05757-800) that is compatible with your motherboard. However, that will not be powerful enough to run the RTX 4060 Ti properly. **It requires 550W w/1x8-pin supplemental power connector .
