Moving sky and gras
I have chosen dynamic gras, but is not moving in the movie.
The wind is turned off.
I also think the sky should be moving slightly or am I wrong?
This is my first video and I probably just missed some setting…?
Hi there! You might want to enable the wind effect to make the vegetation sway; this is more noticeable with plants taller than lawn grass. Regarding the sky, have you enabled the clouds? If you’re looking for a time-lapse effect of the sky, consider adjusting the second shot to the desired time. Thank you.
Hi!
Thank you for your reply!
You were right, the wind was turned off!
I would also like the sky to slightly move, but I can not turn on the clouds here. Do you maybe know why:
EDIT: I figured it out!
Is because I used “HDRI” sky and I should use “Geo and Sky” to customize it.
