Moire effect in my renders
I have a problem with the moiré effect in my renders. No matter the resolution, the effect is very visible. I cannot change the architecture itself because this is the actual design of the residential development and it is not subject to change. What should I do?
These elements cause the problem
hi, that happen when camera pan in certain angle to grooved object. right now only solution is to avoid this angle. take camera little front side .
thanks
Hi @wojciechmarekbudzyn
Please try to disable Super Resolution and Path Tracing.
Super Resolution and FPS Booster
