hi, i want to ask. how can i update my skp model while working by D5? if i reload, all assets and materials will be waste. so, i want to work in D5 and skp at the same time, like in twinmotion
Hi
how did you import skp model into D5? Using sync plugin or importing directly?
Assets will not be lost in D5 if you use the reload function normally. Unless you change the name of the material in your modelling software so that D5 recognizes it as a new material. If the save location of your model file has changed, use the ‘Replace’ function.
as mentioned earlier in other threads: please consider implementing such a “copy materials (with identical name) from selected object”-function!
Working with variants (D5 2.5.1.0319) - Get Help / How to - D5 RENDER FORUM
Thanks for your advice. You’re also welcome to put your needs/suggestions in ‘Ideas & Requests’ part, that will be more helpful for our team to track.
