Good day to all of you, I down load a great lighting fixture from your assets, love it.
The chandelier has its own lihting tone, how can i change the lights or at least bring down the lighting so it goes with my environment and it will not compete.
Thank you very much
Hi, try to select the material of the light, from there you can, maybe give it a color that goes on black orange, then you adjust, then there the value on the illuminating material from 0.1 to 0.2 … onwards.
I hope I have given you some help
Thanks for your help, I tried and can’t reach the light bulb that is the one with the color set (color temperatrue).
I will keep checking out other options.
thanks
I got into the fixture light bulb and I was able to change teh light temperature, just need to move ver yslow and careful.
Thanks a lot, mission accomplished
Or, you can use camera clipping feature that makes it easier for you to slice the lighting fixture models and access the texture surface. That’s way easier than carefully guiding though the viewport.
Thank you very much for your help
