Missing material from Assets
I’m near sure that I downloaded this material from D5 Assets
But I can’t find it anymore. I stored it in Local but I can’t get texture names because file location is greyed. Is there any way to check which texture it use or find it again in Asset Browser ?
Use the Material Picker Tool (Shortcut “I”), then click the surface. There should be information that states the name of the material, and then you can search the material in D5’s Asset library. If it’s from our library, then it should appear.
Yes, but the problem is that I saved it to local using my own name. Is there way to check texture name inside local material ?
Hi @Smolak
Indeed, it will be hard to locate it if you have not remembered what the thumbnail looks like and if it was renamed in your Local Library.
  • Since there’s no option to locate these materials automatically, it’s best to rename them as close as possible to their original asset descriptions.
  • If it’s a wall tile/brick, it should be around in this category.
  • We will consider this as a feature requests, posting it in Ideas and Request is also suggested.
Yes, but I can’t find it anymore in whole Asset Browser. Is that possible that this asset was removed from D5 ?
