Hello, since the installation of version 2.1 I have noticed that the settings of the scenes, despite the update of each scene when i change hdri or sun position, pass on all the other scenes. In other words, it is impossible to give each scene different light parameters. Do you have a solution? I have already uninstalled and installed the software and this also happens on DEMO scenes. Help!!
thank’s a lot
Hi @lucagaudenzi did you check the “Camera Switch Only”?
When Cameras Switch Only is on, the last adjusted exterior and post parameters are applied to other scenes.
Hi @Vicki-Yi !
Thank’s a lot.
It was that fonction activated. I don’t know why
You solved my day.
Have a nice day
glad I can help
