meta quest 3 in D5
Hi there, I’m testing the meta quest 3 in my D5 render pro, a have question about it, can I move the camera through the meta quest joysticks ? Another question is about the quality in oculus will be better in the next D5 version?
Thanks.
Hi @wanfeitosa
Yes, navigation is typically done via joystick-based movement and rotation, depending on your VR setup configuration.
For the VR quality, could you please share a sample of your current VR output or a screenshot/video of what you are experiencing? The quality depends mainly on your PC’s rendering performance and resolution settings.
Hi @ela
I had a borrowed Meta Quest 3, what configuration do you advise me to use on my PC, D5 Render and Meta Quest 3?
My PC configuration is a:
Alienware Aurora R15
13th Gen Intel(R) Core™ i9-13900K (3.00 GHz)
32.0 GB
NVIDIA GeForce RTX 4070 Ti (12 GB)
1 TB SSD
1 TB SSD backup
Best regards
Hi @wanfeitosa
Your PC configuration is already strong for D5 VR usage. However, the VR feature is currently in Beta, so some limitations may occur. For smoother performance, it is suggested to lower heavier effects and use Medium or High graphics settings in D5 VR mode.
You may also refer to our user manual for more details on the setup. How to use VR (beta) Widget? | User Manual
@ela thanks by feedback.
I’ll be eagerly awaiting the final VR version in D5 render. Any idea when that will be?
Best regards!
Hi @wanfeitosa
At the moment, there is no confirmed release date for the final VR version in D5 Render. Rest assured that any updates or official announcements will be shared promptly through our official channels.
We appreciate your patience and continued interest.
