Hi, I can’t merge 2 projects. On widget it does not appear the button to activate merge project.
I tried to go on recent, but there if I click the right button, nothing happens.
Hi @iulia_serb
Can you perhaps record a screen-recording showing the whole process?
Why did the project merger fail??
There may be the following reasons:
The project file is corrupted.
The currently selected file version is lower or higher than the added version.
Project file version is not supported.
Insufficient disk space.
File/folder copy failed.
Merge project location contains files with the same name.
Merge project location is not available.
What need to do before merging projects?
All project files must be saved successfully.
The selected project files must be of the same version.
The archive version must be 2.1 (or later) and support the project merge function.
The remaining free space on the disk where the merged archive is located must be larger than the sum of all the archives to be merged.
