hi, in my renders there are areas of the ceiling that are very dark with black dots. Do you think it’s due to the material or the lights?
Hi @miklam88,
Are you using the same material for all these areas? If you adjust the parameters of the light, would anything change?
Hi miklam88,
there could be something wrong with the mesh of your object. Check it in your 3D software.
it seems surface overlap on each other in that section, check model surface.
hi, thanks for reply. i change something in material as specular and other. Now black area are minimal because there isn’t artificial light in the cieling
You have changed the parameters of the ceiling material. Is the problem of the unwanted dark/black effect still present now?
