Material ID rendering layer
I’m currently working with Material ID as a rendering layer for post-production, and this image is a gradient from red to black, which is difficult to use. I’d like to know if this is normal; there aren’t any clearly defined colors like you usually get with other software. Is this something that can be adjusted? It’s strange.
You are looking at the wrong layer. You need the MaterialID channel, not the AI_Material channel.
Just double check your options before rendering.
Thank you so much, I understand my mistake: I was convinced that this material ID was included when “all post channels” was checked. But no
d5_launcher_LgAyBYc8qW
