Lost Brushed Models U R G E N T
Greetings,
I need urgently a piece of elucidation/advise.
Ones again I have lost some of brushed models.
All layers are unlocked and visible.
All the brushes are in the Brush History whilst a proper layer is activated.
Is there anything I am missing or just a bug?
Thank you in advance for a prompt reaction, if any.
Hi mate, can you show me a screenshot of the scene? Those brushed models do not appear, or they are shown as placeholders or anything else? If you move the model and sync it from modeling software, please check whether the brushed models are in somewhere else in that scene.
Thank you for the info. I did not know that reloading the model the brushes were attached to cause the lost of them.
Fortunately the was nit a case.
The scene has been quite heavy, a lot of scattered vegetation from Sketchup.
Once close and reopen it the brushes are back.
The file in question has for Sketchup 2022 models imported of around 150 mb each.
Mostly tiny and dense vegetation plants.
PS
Once clicking on the brush item in the Brush History nothing happen, no graphic sign of its egistance within the scene was visible, as they did not existed at all.
Hi mate, did you reload the same .skp model as before or a new one? If it is a new model, then the brush history will be removed. Otherwise it can be a bug, we will help you troubleshoot here.
Had similar situation. Planted terrain with advanced brush, all went great. After reopening the file the plants were gone. Looking for solution.
Hi @imkaczmarek
I apologize for the inconvenience. Please check if your Main C Drive Folder (perhaps where this specific file was located) is in a language other than English? Try to change it in English.
We will be fixing this issue completely in the subsequent release. Thank you.
