Hi guys,
I found this new D5 rendering software few days ago. It looks very nice, but it seems that has some bugs or errors. I made my tiny home in 3ds Max with furnitures, desks etc. just like in real-life. Also I tried to render it in D5 with livesync. When I tried to give a color/material for any asset it changed other things as well. They were not grouped at all, I tried to put a material color for wall and that changed also the bed, ground too.
Any idea how can I solve it this problem ? None of them was connected to each other, it’s a bit weird.
Thank you in advance,
Hello sikozsolti.
I can tell you that I use 3D max a little but I use Archicad a lot, for each object or wall and floor in the program I put the textures, which in archicad are the surfaces that I usually have, they have mappings or just the color, but they also have different material names . so when I synchronize in D5 the materials have different names, so D5 recognizes them, because if they have the same name but different objects it is normal that the material changes in the two or three objects with the same material, I hope I have helped you
Hi mate, if the material ID of them(wall, bed, ground) is the same, they will change together. You need to give them different materials in the 3dmax.
It worked ! Thank you guys ![]()
