Hi guys, I ask you why I can’t get a colored liquid material. In the two images you see the same color but simply by changing from custom to water the color changes a lot becoming very dark, there is no way to make it lighter like a colored cosmetic product. The only solution I’ve found is to put the glass material. Even a creamy material I can’t create it.
I noticed the same problem. A fluid or liquid material is difficult to color, it becomes colored only if a very dark color is used but in any case it does not color much.
Hi mate, yeah, it is because that in D5 we have the depth parameter for water material, which make the water look dark. It is suggested to use transparent material instead.
Ok thanks a lot Oliver. Good job
