Lights exceeded 1024
I restarted my d5 file and an error occured like this image
I tried to delete some lightsources and restart the program but didnt work
I cant even open the file.
Is there some solutions to solve this problem?
Or can I just copy and paste my sources to a new d5 file?
I’m using a free trial rn. Is this a problem?
캡처
Need Help… Thanks…
Hi, I notice that the image posted is of the graphics program you use, turning off the light layers does not open D5, you wrote. Do it this way, separate the lights into groups of Layers, for example Group 1 add about twenty lights, group 2 other lights and so on. Having done this, before synchronizing, open D5 and select new, after opening D5 select the type of ambient light you want and already give it the characteristics of the ambient lighting, then go to the effects and give it a bit of contrast and less light shadow is a bit of saturation. Then in this case when you have everything set up, you can open and synchronize your files with the layers of the lights off, then gradually open them one at a time and synchronize. That’s all
Good work
Hi @alskflrk43,
Currently, the maximum number of artificial and spontaneous lights in a viewport is 1024.
If this limit is exceeded, it is recommended to manage the lights within each scene shot using layers or groups, and to hide or remove unnecessary lights for the rendering shots.
