Hi guys, how can I fix those light splotches in this interior animation?
https://youtu.be/CH_l5X6nQHM
The wideo was made with my RTX4070 and D5 render 2.8
Thanks for your sugestions.
Hi there, sorry for inconvenience. Fantastic video despite the light splotches. May I know the workflow that you are currently practicing? There is a possibility that there are material surfaces that are overlapping. and Also you might want to try and change the Environment settings (Light) or the HDRI if you’re using one, since this might also be the cause of the problem.
If any of these did not help, you may want to send us the file at contact@d5techs.com and have it titled “Clov-Forum” then briefly describe the situation. This is for us to test it on our end and examine it further, Thank you.~
Problem solved. I change the hdri for Sky light. But please take in consideration solve the problem for the next releases.
Many thaks for your support
Hi. Would it be possible for you to pinpoint which HDRI you were using that caused the previous problem? Is it from D5 Render itself, or is it a customised HDRI?
A customised HDRI, but Im testing with more acuracy now. I change the curtain material from cloth to foliage and i’m getting best quality render now. Let me try some more tests and I will give you a more precise feedback.
Thanks for your patience and interest.
