Hello is Legacy gi removed in 3.1 update ?
No one will answer ?
Yes, that feature has been removed. Can you please let us know if you still need to use it?
Yes i need because it is faster than path tracing, also quaity is good enough
You can configure it via D5Config.
- Navigate to this path: C:\Users\x\xx\Roaming\D5Config\xxx\usr
- Open it and scroll down until you see [Render]
- Set SharcGI=1 in usr.ini, then save, which takes effect after reboot.
Note: You may input SharcGI if it does not show on your end.
