Bonjour
l’écran de D5 render devient noir une fois je fais la mise à jours de la 3d d’un grand projet sur archicad .merci de me trouver une solution rapide.
Bonjour
Hi @ltstudio.ma
Can you send us a screenshot of how it looks in D5 Render? Does enabling smooth display make the preview window normal?
If that’s the case, then please send us your log file and ArchiCAD file to support@d5techs.com and have it titled Clov-Forum l’écran de D5 noir
Hi @ltstudio.ma
Thank you for sending your ArchiCAD file. We have opened it and activated the live-sync, but it seems to be functioning well. Regarding the files that I have asked please send them too:
Also, can you send us the following information:
Hi @ltstudio.ma
First and foremost, thank you for sending the files that we have requested. Our team has tested your D5 and Archicad file. We have found that this particular issue stems from the excessive number of elements that D5 Render needs to handle. But this was only prevalent on older versions of the Archicad Plug-in, and the newer build has addressed this issue.
Please update your Archicad Plug-in or reinstall with the newer version.
