Hello, did you use plugins to sync, or import the skp file into D5 directly?
If you used the plugin, then it does not matter whether it is skp2021 because all versions are supported. You should make sure the video driver is updated.
If you imported skp model directly, sorry, it is not supported to use “Reload” feature to replace it with a new one, we cannot keep its materials.
(in 2.1, we have auto save feature, I saw you are in D5 Pro server in Discord, I will invite you to the Beta testing group)
Hi, a second back up file may take up more spaces on your drive. But in 2.1, we will have auto-save feature as backups, which backs up version history every 5 or 10 or 60 minutes.
Welcome to try 2.1 beta and help us test its features.
