Hello everyone,
I’m using the path tool in D5 Render to add characters and cars to my scenes, but I’ve run into an issue when rendering multiple images.
When I re-render the same view, the path objects (people and cars) appear in a different position because the path keeps them in constant motion. This causes a major problem for me when I try to edit my renders in programs like Photoshop, as the images don’t match up.
My question is: Is there any way or trick to “freeze” or keep the path objects static in a specific position so they appear in the same spot in every render? I’m looking for a solution that allows me to maintain a fixed position between renders without having to place the objects manually.
Any help or suggestions would be greatly appreciated! Thank you in advance.
