It’s just a common question. Is the RTX 2070 good for D5 render?
Many people, including myself, are still using this model or even older graphics cards. Additionally, I also use a 3D scanner in conjunction with D5. The consumer-grade scanner I use from Revopoint doesn’t have particularly high computer requirements (though some more professional scanners do require higher specs), so I haven’t upgraded my computer configuration. I would like to ask if using the RTX 2070 would cause lag or other issues when running D5? What kind of computer configuration is needed to achieve good performance with D5 Render? This will determine whether I need to buy a new computer.
The answer I got through a google search is that it’s possible. It just might not be as efficient as a more advanced graphics card. I’d like to hear a professional answer.
