Is it possible to export the material in the D5 render?
Is it possible to export the material in the D5 render? I’d like to put the material somewhere else after the export.
Hi @likeneke
It is not possible to export these materials outside of D5 Render. Thank you.
Then, with the material value in the model, can you put the same material value in the new model? Or should I put them in one by one?
Hi @likeneke
You can try to put the material you have used in the previous model in your local library~
THX
I try use my local library!
