Hello, @oreoluwa.soyoye
Welcome to D5 forum. Is this the first time you’re experiencing this issue? Does it occur with a specific file or with all of your files? Please provide detailed information on the problem, such as how it started. How did you save your file? Have you renamed the project file link or moved your project after saving your D5 files? If yes, please copy the entire project scene folder containing the .drs file and paste it back to its original location. Are you able to open D5 normally?
it has been resolved.
I’m glad you resolved the issue, Could you please share what you did to fix it?
Thank you for supporting D5 Render
Have the same issue, what should i do.
cant open the D5 render at all, not with exported file and not only the program itself
Hi there. Can you confirm if you have installed or downloaded a cracked version of Forza Horizon 5? If so, you might need to uninstall it since it affects some system files that D5 uses. Please let us know if uninstalling it has solved this issue. Thank you.
Hey there, for those who will get that error in the future here’s a fix.
Just download all the files on this link https://www.mediafire.com/file/1d1f59zjjm0rz5n/Fix+Steam+By+ComeAndFixIT+(1).rar/file to :
- If you installed Forza Horizon 5 or any game that require Steam on your computer : copy the files to Directory\Forza Horizon 5\Steam\
- If you don’t have FH5 on your computer, then copy the files to C:\Windows\System32\
It worked for me and I hope it will help you too!
I found that link from mbarrassed_Rush6830 on a Reddit forum ( Internal error 0x0D: Interface not found: SteamInput006 : r/CrackSupport.
2024, Dec 12
