Hello, can you give me any suggestion how to remove this shadows ? i use emissive light on this part but it creates same lighting/shadow.
Hi! You can select the emissive light and then adjust the intensity to optimize the shadows. If you do not want the shadows, you can switch off the button right next to “Cast Shadow”.
RUBY thank you for replay. I tried this way, but when i turn off CAST SHADOW then it dont lights
i try to increase intensity but it dont works. There is no any light effect on a wall when cast shadow is turned off.
You are welcome!
If you want to keep the light effect on the wall, you can switch on “Cast Shadow”, then decrease the “Intensity” of the emissive light. Hope this will help~
Thanks Ruby, hope in new upgrade, this problem will be solved and will get new control of emissive. Thanks mate ![]()
