2026-02-21 14:22:34 Start check installation files…
2026-02-21 14:22:34 D5Render installation verification failed at path: C:\Users\Uğur REDANTARC\AppData\Roaming\D5\D5 Render\d5_launcher.exe
Hi @u.yagcitr
Could you please elaborate on the issue?
The message: “D5Render installation verification failed at path: C:\Users\Uğur REDANTARC\AppData\Roaming\D5\D5 Render\d5_launcher.exe” means that the Sync plugin is unable to locate or verify a valid D5 Render installation on your system. In other words, the file d5_launcher.exe is either: missing, corrupted, blocked by antivirus/security software, or installed in a different directory than expected
Please check whether D5 Render is properly installed and opens normally. If D5 does not open, uninstall D5 Render completely and perform a clean reinstallation.
