After updated to 2.6 the inspector/transform lagging, when I’m done moving/rotating/scaling object A, and start to select another object, lets call it object B, and do some transform (moving/scale/rotate), the object got transform is object A not B. This happen over and over and over again, not only in transform, it happen when I edit the material too. Anyone have the same problem?
I have the same issue, its didn’t happen yesterday when i haven’t updated to V2.6
Assets do not load, material are downloaded partially and The software closes suddenly, old files do not open, error message is seen.
Problem fixed by update Graphic Driver, in this case I use RTX 4090 with Studio Driver Update
