I am a completely new user of D5 Render, but have previously used Lumion a lot.
Is it possible to import an Autodesk Infraworks model into D5 Render, so that you get a good sense of the surroundings when creating 3D visualizations for large factories? Or are there other terrain models that give a better sense of the surroundings?
Hi, Direct connection between Autodesk Infraworks and D5 is not supported at this time. But you can export the model from Autodesk Infraworks and import it into D5.
Hi, D5 currently does not support importing fbx models with textures. If you imported the model using the fbx file format, then you can manually apply textures of the model in D5.
Hey Ryan. Do you have another great way to visualize real ife surroundings, without having to apply textures? We really like the look we get from the infraworks model, because it shows hills/mountains, roads, fields etc.
