I have placed lights within a component in Sketchup. There is an inconsistency in the lighting effect shown D5. The lighting shows up for some components but not others. Hopefully the attached image clarifies the issue. Any ideas?
Hi orri,
It is because D5 combines some lights to enhance the computer performance.
In final rendering, the effect will be more accurate.
Hello mate, the second scene you posted is not the same one as the first post.
To confirm, the lights are from SketchUp?
Can you compress the scene file and skp model file, then send them to support@d5techs.com?
We may need to check the file to see what’s wrong with the light objects inside components in SU.
Thanks,
Oliver
