Does this have anything to do with not having enough storage?
Hi mate, you encountered this same error message? Has the file once saved before? If yes, then you can go to that project folder, copy and paste them manually to somewhere else whose space is enough.
If the file has not been saved once, then you may need to check the permissions of the folder you try to save files in. Also, if the file path contains special characters or some unsupported languages such as Turkish, then please move the file to an English file path instead.
Yeah,
Im encounter this message. Our compant has been make a number of server changes and at the moment were out of space. I’ve relocated the file to a different drive and all works normally.
Thanks for the updates.
