I have a problem. The project file does not preserve material setup for imported animate objects in alembic format.
After setting the materials and saving the project I’m closing it and each time I open it again, the materials are going back to default white material. Can you please help me?
Hi there,
I apologize for the inconvenience this issue has caused. Currently, the import of .abc files with textures is not supported in D5. You will need to separate the textures in modeling software and then re-apply them in D5. We will consider adding support for this in future iterations.
Additionally, the D5 2.6 version began to support FBX import with materials but does not support complicated material nodes. In this case, it is recommended to import directly or use converters to import the model into D5. ![]()
