is there support for import in place feature or the same axis directly in d5? because in some rendering projects I need this when several different sketchup files have to be put together, usually on projects with a large area and many buildings whose interior files are different from the original sketchup file, it would be useful to get the same axis
please help, thanks
Hello, if you mean you want to keep objects’ origin coordinates in modeling software, this will be supported in the coming 2.2 version. The beta test will start soon, and you can join our Discord server to try it.
For now, if those objects are from one skp file, then you can multi-select them, and click this button to align:
uuh! Can i join discord too? Can u send the link a private message?
Im also excited to test new beta!
Hello, yes you can, I will send you in private messages.
By the way, we will send you emails after you purchased D5 pro, and it contains the link to Discord server.
