i have an issue. I’m not able to import objects. If i import d5a or fbx for exemple, i can see it in the list of imported objects, but my scene is empty.
If i start a new scene by importing it (new > from model file) it works, everything is ok.
Sothat way i can’t import multiples files, only the first one works
Once you see the imported file in the list, you put your cursor over and see a bin to delete and an arrow next to it to actually merge into the scene. Hope it helps.
In some tutorials on the Web, you are able to do this by drag&drop from the list. Unfortunately it doesn’t work anymore in the current version (1.7.1)?!
