^ Full Screen^
^ Minimize & also hide my taskbar^
Hi, im new in this community & D5 Render. I’m impressed with the render engine that look fantastic. But i have a problem when i run it. Everything is fine, the only thing i cant understand is the display when i click on image render menu. The menu is too down & cant fit when i try to fullscreen it or minimize it & hide my taskbar. May i know you guys answer for this problem i had? Thank you.
Hi, it may be related to the resolution of your monitor, may I know the resolution of your monitor?
I did change my monitor & display resolution but it still didnt work. But the problem already solved by installing the 2.2 version of D5 Render. It is works, but sometimes i want to try the latest version. Thanks for answering mate.
Hi there, thank you for the feedback. But I believe the issue is not related to D5 versions. May I know what’s the screen size of your monitor? If it is 16:9, please try to set the resolution to 1920x1080 or 2560x1440, to test if the issue still exists.
