After the recent update, I’m having kind of stuttering in D5 render. The movement feels sluggish. It happens suddenly and couldn’t find any specific reason for this. Any Idea why this is happening?
My Pc:
CPU: i7-11th gen
Ram: 32GB
GPU: RTX 4060ti 8GB
Thank you for including a video recording. In the video, D5’s movement depends on the movements made in your SKP file, as you have activated the livesync plug-in and moved or hovered the preview screen inside the 3D model. Therefore, a slight delay is to be expected.
Additionally, the performance may be affected by how your device handles the file, particularly since the D5 file appears to contain many vegetation assets, which can cause a drop in FPS.
I’ve also tested it on my end but only with a simple SKP File linked via Livesync. Video Recording: Unique Download Link | WeTransfer
Try checking the current VRAM Consumption on your end to see if it’s nearing the maximum capacity. Open the task Manager while these files are activated then see if it’s nearing 8GB VRAM Consumption.
