Illegal File Name
It seems like some internal names cannot be used as names for imported object. Tried naming an object “Concrete” but it reverts to “crete_” with an error “File name illegal Concrete”
Upon further testing, it’s not “Concrete” causing issue but the prefix “Con”
Upon further testing, it’s not “Concrete” causing issue but the prefix “Con”. For example
“Con1” is not allowed but “1Con” is fine.
Hi @ar.talhamuftee
May I know which file format was used here? I tried it on SKP and .d5a format, but the error prompt does not appear, nor does it change the object’s file name.
  • Which D5 build are you currently using? Please use 2.11.1.0620 if you’re not in this version.
Hi @ar.talhamuftee
We were able to replicate the issue, basically the object needs to be renamed inside D5 and not the file itself. I have forwarded this further to our team for further troubleshooting.
