hello, i’m new to the community but i’ve been using d5 for a while. i’m having a problem when i export the lighting in the project via live sync. i use manufacturers ies file to carry out the study and have more precision in the lighting specification but when i send the lighting via live sync it loses all the spot light settings and comes up as point light, without any of the ies file settings that should be configured. please could you check this? i would also like to suggest a view mode similar to the one we have in dialux evo or relux to do all the lighting studies directly in livesync of the d5, so we can have more precision in the lighting in the projects and the reality.
Hello, thank you very much for your interest and suggestions for the D5. I think your lights are missing because D5 does not currently support the format you are using. We are always improving our software and will add more features in the future. I suggest you can leave your suggestions in the forum, this will allow your suggestions to be seen by more people and may be able to accelerate the adoption and application of your suggestions.
Latest Ideas & Requests topics - D5 RENDER FORUM
Thanks @LunaLang , I dont understand why its happen because im using a properly archicad object light (.gsm) from the manufacture ( simes) that delivery the objects to use with the properly ies file in it. and when i use send lights its became a light point instead light spot ligght with the right ies files light. In point of view it should work properly when we send the lights from live sync. i hope it correct asap.
