Hello, good day. I’m trying to use the AI Enhancer, but when I try to generate the image, I get a “Not Found” message. Do you know what could be causing this?
This error prompt usually shows if the original rendered image was either transferred or renamed.
If this is not the case, can you send us a videorecording showing the whole process?
