The file resulting from exporting from revit 2023 does not contain information, models, materials or any element to work with in D5 Render, in fact it cannot be saved
Hi! @arkhitekton.gc Are there any error messages? It would be better if you could show me some screenshots. And Did you use the Revit plugin to synchronize the model or export in .rvt, then import directly to D5? If you use the plugin, which version do you use, please?
Hi! @arkhitekton.gc Was this issue solved? And sorry for a mistake in the message sent before. Did you use the Revit plugin to synchronize the model or export a .d5a file and then import directly to D5?
What is your Nvidia video driver version number? This may happen if you are using 46x.xx video driver. Can you first try updating your Nvidia driver and try again?
Besides, if you use AMD graphics card, please try this beta version, which supports AMD now: D5_Converter_Revit_usa_0.3.9.9.zip - Google Drive.
