이번에 새롭게 교육용 라이센스를 신청했습니다. 학교 이메일과 나머지들을 등록을 했지만. 메일로 답변이 안오는 중입니다. 학생증의 앞뒷면을 찍어야하는 것은 제가 학생증이 없는 관계로 d5에서 제시한 방법으로 등록을 했지만 제 사진은 홈페이지에 없어서 그 부분은 제외하고 등록을 했는데 이게 문제가 되는건가요?. 그리고 라이센스 신청결과는 학교 이메일로 결과를 알 수 있는지 아니면 제 이메일로 알 수 있는지 궁금합니다.
Thanks for reaching out. May I ask which email address you used to submit the application? Also, did you apply directly through the D5 Launcher, or did you complete the secondary verification via the Google Form?
If your application was successfully submitted, you should receive the result via email within 7 business days. The notification will be sent to the email address used during the application process. ![]()
I submitted my application by selecting [Get D5 for Education] in the D5 Launcher account section, which led me to a Google Form.
The Google account used for the submission was [21o2392@gmail.com].
Thanks for providing the details. I’ve checked your submission and found that you already have an existing educational email address. Please use that educational email to apply for the D5 Education License, as applications submitted with personal email addresses cannot be approved.
Additionally, kindly make sure that you have created a D5 account using your educational email before submitting the license application. ![]()
I applied using my educational email address quite some time ago, but I have not yet received approval.
I was wondering if you could let me know when I might expect to receive it.
My educational email address is:
202242065@itc.ac.kr
I would appreciate it if you could check on this for me.
This matter is quite urgent for me at the moment, so I would sincerely appreciate your assistance.
Thank you very much for your time and support.
