How to Render Shadowlessly (without shadow)
Greetings,
Is there any method to achieve my goal to get some composites to be used in Photoshop from D5 Render as follow?
I need a separate render of some elements, especially some vegetation without shadow and the shadow rendered apart.
For this second part I can use AO channel.
I will appreciate any piece of advice.
Many thanks in advance.
Hi mate, for now we do not have that feature. Maybe you can try this workaround: Choose the materials, then enable “invisible in raytracing”, and they will not generate shadows anymore.
(This can work in 2.3, but now in 2.4 there is a bug that the function cannot work for plants in D5 library, therefore, you may need to change materials for the plants or wait for our fixes)
Thank you. Good to know.
Still have the isdue with huge amount of brushes. They are not shown nowhere.
The only way to reviver their visibility is to reopen the file.
And it takes time.
Also there is no possibility to SHIFT select brushes within Brush History.
Annoying in case of many of them.
Best regards
Ok mate, we will take this request into consideration. Maybe we can support this feature in future.
