Is it possible to move this terrain area? I found out that it is far away from my site only after setting all the scenes, but didn’t figure out the way to move it. I’ve checked my model and in every group the 0 of all axes are in the model, not that far away.
Hi there @istrodion
It is not possible to move the terrain area. You may need to move your model inside of it, please try to unlock your model then move manually using the arrows.
- Can you send me a screenshot of your model info (Inspector) which shows the XYZ Location Values?
Thank you.
You can select the terrain in the left panel, then in the right panel, under ‘terrain area setting’ you adjust the position. It does not update until you click ‘adjust’ button
