After importing from a SketchUp file, I changed the wall surface to D5 material. After working on another task, I need to modify the wall surface material, so I try to change it again, but when I select it, a different screen keeps popping up instead of the modified material.
When I click on the screen, the lnspector screen pops up and only the entire surface I worked on in SketchUp moves.
When I grab a new material and create it next to it, the material modification screen pops up on the lnspector screen.
Summary: I want to modify the modified material again.
Please try to click the Letter “I” key first before selecting the surface, this will change the cursor into an eyedropper icon then proceed to select the surface and modify it.
